Sunny, Friday afternoon, why am I here moment?
Anyway, if I start a new Window from the Window template, go to the exterior elevation view, start a new solid and pick out a rectangle where the bottom edge is coincident with the Top reference plane, I get a lintel that moves when I change the height parameter. Cool, as expected.
Now I delete that solid and do another that is just floating free, no pick points on any reference planes. And yet, the lintel still moves! I turn on Automatic Sketch Dimensions, click my lintel solid, and I get one that references the Reference Level, not the Top Reference Plane. But the lintel moves with the Top Reference Plane. Not cool!?
If I place a new Reference Plane and don't lock dimension to the Top Plane then I finally get a stable solid. Now it seems to me that if there is an implied relationship between that solid and the Top Ref. Plane then I should see an Automatic Sketch Dimension to that effect. And if I didn't pick any points on a reference plane, then there should be no implied relationship, and my lintel shouldn't move until I lock dimensions.
So, is this a bug, or at least an oversight? Or is this intended behavior that I somehow don't understand? Or is this some greater power saying "Go get on the motorcycle, the weather is too nice for Revit!" ?
Gordon
