Thread: AutoCAD 2008 - Solid extrusion error - Lateral curve does not intersect to_surface
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    Unhappy AutoCAD 2008 - Solid extrusion error - Lateral curve does not intersect to_surface
    Hi,
    Back on AutoCAD after a slight hiatus. I'm currently on ver 2008 for the 1st time. Trying to do a 3d extrusion and coming up with this error message:
    Modeling Operation Error:
    Lateral curve does not intersect to_surface.
    I created a closed 2D Polyline (at least that's what shows up on the propoerties) all points on the same elevation / Z value. No arcs in the polyline.....What's going on?!?!?!
    2004-05
    Brisbane, Australia
    405
    Default Re: AutoCAD 2008 - Solid extrusion error - Lateral curve does not intersect to_surface
    Quote Originally Posted by Merlin
    Hi,
    Hmmm...I've got the extrusion now after "flattening" the polyline. I can't figure what went wrong in the first place though. At first I made sure the UCS was set to world and with that UCS setting I went to maximum decimal places. it showed no Z value differences
    *shrugs*
    13,656
    Hi
    Ignore the Applies to, and see if the following offers any help...
    ID: TS49657 - Error: Lateral curve does not intersect to surface
    Have a good one, Mike
    2004-05
    Brisbane, Australia
    405
    Talking Re: AutoCAD 2008 - Solid extrusion error - Lateral curve does not intersect to_surface
    Quote Originally Posted by Mike.Perry
    Hi
    Ahhh!...Thanks Mike. So it wasn't just me! Thanks again, mate
    John Mc
  1. 2013: Roof - Extrusion Along path - Conceptual Mass - 3D curve
    By libre in forum Revit Architecture - Families
    Last Post: 2013-04-26, 01:26 PM
  2. curve intersect result
    By sfaust in forum Revit - API
    Last Post: 2009-04-28, 03:19 PM
  3. Has transparent Solid Hatch been added to AutoCAD 2008
    By clucas.116254 in forum AutoCAD General
    Last Post: 2008-06-07, 05:07 AM
  4. Intersect a solid with a surface?
    By madlyons in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-01-04, 01:44 PM
  5. AutoCAD 2008 - Make a hole in a Solid
    By kwong in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-05-15, 11:59 AM
