Results 1 to 6 of 6
Thread: Convert Objects that require Object Enablers to normal AutoCAD entities
    2001-02
    4
    Default Convert Objects that require Object Enablers to normal AutoCAD entities
    You get one of the dwgs from someone that ACAD says it is searching for Object Enabler(s)... How does one readily take those objects and make them into just plain AutoCAD entities, without DXF the entire dwg? LISP to search and replace? Other methods? Tools to highlight?
    Thanks!
    ~Terry
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Default Re: Convert Objects that require Object Enablers to normal AutoCAD entities
    With the object enablers showing the 3rd party objects, you should be able to explode them down to AutoCAD primitives.
    2001-02
    4
    Well... maybe... but what if an object loads that does not have an enabler per se? i.e.
    Loading AecCivilBase...Checking for object enablers on the Autodesk website
    AutoCAD has not found an object enabler on the Autodesk website for ObjectDBX
    Classes
    AutoCAD has not found an object enabler on the Autodesk website for EXAC_ESW
    Classes
    Also, if you do have objects with enablers in Vanilla AutoCAD... how does one select / highlight just those entities?
    Ciao!
    ~Terry
    2015-11
    Edmonton, Alberta
    990
    Well, if no enabler is found, then AutoCAD will put in a proxy instead. You can go the the Autodesk website and download the enablers yourself if you routinely get files with AEC objects in them.
    13,656
    Hi
    Depending on the version of AutoCAD you are running, -ExportToAutocad and_or AecToAcad commands may prove an option...
    Have a good one, Mike
    2015-08
    WISCONSIN
    46
    This may not be the most sought-after solution, but it worked. Thanks for the tip.
    I had a set of proxy objects that I could see in my model when I opened it in 2015 with a Cadworx 2013 object enabler installed. My coworkers couldn't see the proxy objects in 2013. I exploded the proxy's to surfaces and they could be seen in 2013 then...
    I would rather have been able to leave the proxy objects as "objects" rather than a unconnected bunch collection of surfaces.
  1. 2004: Object Enablers - aeccland for AutoCAD 2004
    By larry.lesser534497 in forum AutoCAD General
    Last Post: 2014-02-04, 08:35 PM
  2. Replies: 6
    Last Post: 2012-04-09, 09:47 PM
  3. AutoCAD Electrical 2011 looking for Civil 3D Object Enablers
    By leah.aston977850 in forum AutoCAD Electrical - General
    Last Post: 2011-07-29, 01:27 PM
  4. Why is AutoCAD Electrical looking for Civil 3D object enablers?
    By leah.aston977850 in forum AutoCAD Civil 3D - General
    Last Post: 2011-05-20, 12:39 PM
  5. Object Enablers not working with AutoCAD 2009
    By marcusnewport in forum AutoCAD General
    Last Post: 2009-02-23, 11:18 AM
