is there (and where would i find) the graphic control for the revision bubble. can you assign a linewt and color?
Settings> Object Styles > Annotation Objects > Revision Cloud(s) & Tags
THANKS! i knew it was in there somewhere.
and while we're at it can we change the way the actual line displays, ie a uniform curve, rather than one big and one small?
Nope. It's all you've got. You can change the line weight and color, but not the geometry of the lines.
Hopefully someone at Autodesk will make revisions work better across the board in the next Revit revision. I'd also like them to be associated with objects rather than be a drafting element (or both). Then there's the revisions of schedules issue...
