Thread: How to update Xdata on existing entities in ACAD with objectARX?
    2007-06
    15
    Question How to update Xdata on existing entities in ACAD with objectARX?
    Hi,
    I am writing a C# application for ACAD using objectARX. I need to update the Xdata in a DBDictionary. I can get to the correct Xdata and iterate through it fine. My problem is when I try to modify it and I commit my transaction and save the database none of the changes get registered. I am posting some code bellow. Any help will be greatly appreciated.
    TypedValue[] Xdata;
    Database db = new Database();
    Transaction trans=null;
    ResultBuffer newXdata=null;
    DBDictionary datadic=getDictionary(file.FullName);
    //getDictionary just return a copy of the DBDictionary that I am looking for in a file
    //that I open through the ReadDwgFile() command
    //I used the switch command to create a modified copy of the existing Xdata
    //because the TypedValue.Value and TypedValue.TypeCode are read only
    if (datadic != null)
    Xdata = datadic.XData.AsArray();
    TypedValue[] tempXdata=new TypedValue[Xdata.Length];
    for (int i = 0; i < Xdata.Length; i++)
    switch(i)
    case 6: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, file.FullName);//'location
    break;
    case 7: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, System.DateTime.Today.ToString("MMMM d, yyyy"));//'last mod date "MMM dd, yyyy"
    break;
    case 8: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, HEISU_Forms.HEISUforms.HEISUfrm.UserName);//'last mod by
    break;
    case 9: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, projInfo.projectDescription);//'Project Name
    break;
    case 10: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, projInfo.projectNumber);//'Project Number
    break;
    case 12: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, HEISU_Forms.HEISUforms.HEISUfrm.UserName);//'Creator
    break;
    case 16: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, projInfo.fullStateName);//'full state name
    break;
    case 20: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, projInfo.logoState);//'1 if logo is legal, 0 for eor
    break;
    default: tempXdata[i] = new TypedValue(Xdata[i].TypeCode, Xdata[i].Value);//transfer all other Xdata
    break;
    newXdata = new ResultBuffer(tempXdata);
    try
    DBObject obj;
    db.ReadDwgFile(file.FullName, FileShare.ReadWrite, false, "");
    trans = db.TransactionManager.StartTransaction();
    obj=trans.GetObject(datadic.ObjectId, OpenMode.ForWrite);
    obj.UpgradeOpen();
    obj.XData = newXdata;
    newXdata.Dispose();
    obj.Close();
    trans.Commit();
    trans.Dispose();
    db.SaveAs(@"U:test.dwg", null);
    finally
    try
    db.CloseInput(true);
    catch { }
    2007-06
    15
    Default Re: How to update Xdata on existing entities in ACAD with objectARX?
    If anyone is interested I found the answer to my previous question. I had to move the code from the getDictionary to the main function thus allowing me to open a connection to the ACAD db only once with ReadWrite access. That fixed my problem and the Xdata did get updated after that.
  1. Lisp file to delete All Xdata from selected entities regardless app name
    By diaa.caliph423218 in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2015-09-29, 08:33 PM
  2. Replies: 6
    Last Post: 2015-08-31, 04:05 PM
  3. can't update existing dwg file
    By romy8111 in forum AutoCAD Electrical - General
    Last Post: 2010-01-18, 10:10 PM
  4. can't update existing dwg file
    By romy8111 in forum AutoCAD General
    Last Post: 2010-01-12, 10:25 AM
  5. Converting ABS entities to ACAD solids?
    By jnewell in forum AMEP General
    Last Post: 2005-01-07, 12:24 AM
