Thread: A Mvpart problem
    2006-10
    14
    Unhappy A Mvpart problem
    I am trying to learn to create Mvpart by using ABS. Today I made one clean out for drainage system. But get an error: "Part type parameter not validated. Validation Summary--Level 1 Errors Found".
    I went through my work, but can not find what caused the error. Would anyone give me a hint?
    I attached the clean out with this post.
    Thanks in advance.
    2006-02
    424
    Default Re: A Mvpart problem
    Have you found the answer to your question yet?
    I have a couple of blog posts about MvParts that may help you out. I'm guessing that maybe you didn't go thru and validate the catalog before trying to drop the part in. Also make sure you save the drawing that is housing your MvPart and exit out of that drawing before trying to access the part. Here is the website: http://abbie-abs.blogspot.com/search?q=mvpart
    My main blog site is: http://abbie-abs.blogspot.com/
    Good luck!
    2006-10
    14
    Talking Re: A Mvpart problem
    Quote Originally Posted by ameador
    Good luck!
    Thanks. it has been solved. Can't find your blog. However thanks a lot.
    2006-02
    424
    Glad your problem has been solved!
    Site address is:
    It should pop right up unless you all have some sort of strange website blocker.
  1. Classification MvPart
    By bast.jean380633 in forum ACA General
    Last Post: 2013-11-22, 03:11 PM
  2. MVPart visibility
    By Gaz62 in forum AMEP General
    Last Post: 2009-11-05, 08:17 PM
  3. MVPart connection problem
    By kmf2797 in forum AMEP General
    Last Post: 2008-08-22, 06:02 PM
  4. EDIT MVPART
    Last Post: 2008-06-03, 08:58 PM
  5. mvpart System
    By buzz in forum AMEP General
    Last Post: 2008-01-10, 06:38 PM
