Is anyone else having trouble with wall outlines or ceiling grids disappearing when exporting to .DWG format from Revit 2008?
Our engineers don't want separate .DWG files for floor plans and reflected ceiling plans -- they want everything in one file. We used to produce these by exporting an RCP view that had a floor plan as an underlay [Revit Walls.GIF]. This worked (if you turned off the casework before exporting) in Revit 9.1. But Revit 2008 is giving us fits.
If we select wireframe for the export, outlines of random walls do not get exported at all. For some such walls, the hatching for the wall gets exported, but not the lines for the actual sides and ends of the wall [RCP-Wire.GIF]. There seems to be no way of predicting which walls export properly and which have no outlines. Two walls can be the same wall type, have the same bases and heights, and have the same nearby ceiling types, and yet one wall will export properly, and the other will have no outline.
Of course, exporting with hidden lines removed is not an option -- this causes wall edges to be trimmed in places where a ceiling edge or casework edge overlaps them, and this makes the .DWG a mess if you ever turn a layer off [Hidden Line Removal.GIF]. Supposedly, the wider line always takes precedence over the thinner line, but in practice, this isn’t the way it works. (The green lines in AutoCAD are edges of ceilings, lineweight 1 in Revit, whereas the wall outlines are lineweight 6.) Random walls still disappear, though they are different random walls.
I've tried exporting to both 2004 and 2007 file formats -- no difference.
I've tried using the RCP as an underlay in the floor plan (instead of vice-versa). This works better in that all of the wall lines seem to show up, but the ceiling grids do not. In the export layer settings, the surface pattern for the ceiling is assigned to layer A-CLNG-PATT, but no such layer ever gets created in the DWG file, despite the ceiling grids being visible in the Revit view [Floor Plan.GIF].
If we don't use underlays, we can export the RCP and floor plan separately -- no missing lines result. Then we can insert one DWG into the other as an exploded block, but I am trying to find a less time-intensive, less screw-up-able process.
Has anyone else had this problem? Has anyone come up with a proper solution?
Scott Johnson, Ph.D.
CAD Manager
Richard L. Bowen + Associates
