Thread: Audit is slow when run multiple times
    2005-09
    13
    Default Audit is slow when run multiple times
    Hello everyone,
    We have encountered a problem that is increasing daily. As a routine, we run the audit command on our drawings often to clean up extraneous errors. Lately, we have encountered a huge delay (several minutes) between the first and second pass of the audit. Once the second pass begins, it is very fast, as was the first, it is just a delay in between that is killing us.
    I thought that it had to do with large numbers of x-references or with non-zero Z coordinates, but eliminating these do not seem to remedy the situation.
    Anyone have any ideas?
    Charlie
    2005-08
    Albania
    423
    Default Re: Audit is slow when run multiple times
    Quote Originally Posted by charles.stewart
    Hello everyone,
    Charlie
    What parameters has your PC.?
    2005-09
    13
    All these PCs are top notch with 3 GB of Ram. I don't think the issue is with the machines, but more the drawings. Some drawings, even large ones, breeze right through the process, other smaller files hang for minutes.
    Charlie
    2005-08
    Albania
    423
    Charlie
    To large drawings maybe you should to use Purge command for unless properties.
  1. 2014: Really slow render times
    By Craig_L in forum Revit Architecture - General
    Last Post: 2015-03-19, 08:18 AM
  2. SUPER SLOW save times
    Last Post: 2009-12-11, 05:28 PM
  3. Slow Plot times
    By kevin.conner in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-09-15, 08:35 PM
  4. Slow load times max2009scene
    By wimpandora in forum 3ds Max - General
    Last Post: 2009-08-06, 02:03 AM
  5. Rendering Slow sometimes & Fast other times
    By josh.made4worship in forum Revit - Rendering
    Last Post: 2009-03-16, 02:23 PM
