Thread: Maximum Family File Size Recommendation
    2005-09
    Perth Australia
    470
    Default Maximum Family File Size Recommendation
    Hi All,
    Can someone recommend a maximum file size for a Revit Family.
    I thought I would be smart and nest 9 door panels into a door family but the file size is 1.25MB. I have a feeling someone once suggested keeping it under 500K. Is that correct?
    Thanks,
    Rob
    Count (Formula) dbaldacchino's Avatar
    2005-07
    Missouri City, Texas (Houston area)
    3,250
    Default Re: Maximum Family File Size Recommendation
    I've found that size isn't really an issue (similar to project files). Lots of nested families within nested families can cause your family to act slow. And arrays are the real killer. But most often, the advantages of managing everything in one family outweigh the other setbacks, even if the family is a bit slow to react to changes in parameters.
    2005-09
    Perth Australia
    470
    Thanks David.
    This particular family is a little slow but it is very nice to be able to swap door panels without going through long lists of doors or loading them in from the library.
    I will bear in mind your comments about arrays and the layering of nested families.
    Rob
  1. Is there a Maximum Network Size in Civil3D 2012?
    By AAristizabal in forum AutoCAD Civil 3D - General
    Last Post: 2012-08-30, 04:29 AM
  2. maximum dwg file size?
    By Maurice.148748 in forum AutoCAD General
    Last Post: 2010-11-20, 04:31 PM
  3. Maximum File Size
    By NKramer in forum Revit Architecture - General
    Last Post: 2010-06-22, 03:25 PM
  4. Allowable Forum file attachment types and their corresponding maximum file size
    By Mike.Perry in forum Forum Tips & Tricks (Read only)
    Last Post: 2007-05-28, 08:19 PM
  5. Maximum paper size from ACAD to HP Designjet
    By Haden in forum AutoCAD Plotting
    Last Post: 2005-10-06, 09:29 PM
