I'm using 2002 and I have old lisp routines. this particular problem comes up when I use the custom dim commands.
for example:
The text window then opens. How do I bypass text window?Code:(DEFUN C:DH() (COMMAND "DIMSTYLE" "RESTORE" "DIM" "LAYER" "SET" "DIM" "" "DIM" "HOR" PAUSE PAUSE PAUSE "" "EXIT"))
Thanks - perplexed
