Can anyone help me grade a house pad using feature lines?
Here's my setup: I have a corridor along with the corresponding proposed contours created. I want to add grading around a building pad into that surface. The closest i've gotten is to draw a feature line and set the elevations, but when i "add the featureline to surface as breakline" it doesn't grade around the house the way i want it to. Can anyone help with this?
Also, when i draw a "box" using a feature line and set the elevations and grades, the contours ALMOST do what i want. It will put the contours exactly where i want them at the corners of the "box" but then will dip back down to its original elevation. Any thoughts? Thanks in advance for your help.
-Andrew
