Results 1 to 7 of 7
Thread: AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    2006-10
    7
    Default AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    I've been running 08 for a few weeks now with a minimal amount of disruption.
    All of a sudden my sheet set manager won't work. The menu opens fine and it prompts me to open a sheet set. I select a sheet set file and it won't open it in the manager. The manager won't open ANY sheet set files. Any suggestions?
    13,656
    Question Re: AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    Hi
    Has anything recently changed on your system?
    Have you run any kind of Registry Cleaner / Repair utility?
    Have you tried running a Repair / Install on your AutoCAD 2008 installation?
    The following is probably not related, but just in case...
    ID: TS1063349 - Error: Sheet set file is not valid
    Have a good one, Mike
    2006-10
    7
    Default Re: AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    Quote Originally Posted by Mike.Perry
    Hi
    I can't find the repair utility on the disc.
    13,656
    Quote Originally Posted by sjz
    Hi
    Windows Start menu -> Control Panel -> Add or Remove Programs -> Select your AutoCAD 2008 installation -> Click the Change / Remove -> AutoCAD 2008 Installation Wizard - Maintenance Mode window should open -> Select the Repair or Reinstall option -> Follow the remaining prompts, selecting the appropriate options.
    2007-08
    2
    Quote Originally Posted by Mike.Perry View Post
    Hi
    sjz,
    Try this. If you still have an older version on your computer remove it with Add/Remove.
    In my case i then ran PC Rescue.
    Then using Add/Remove to bring up the Repair option on the ACAD disk which must of course be in the drive.
    Reload ACAD and try sheet set manager pick one of your sheet sets
    2006-10
    7
    IT's all fixed!
    Thanks guys and/or girls!!!!
    2007-08
    2
    Smile Re: AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    Quote Originally Posted by robotrin View Post
    sjz,
    Best of luck
  1. Sheet Sets and AutoCAD Electrical?
    By tonofsteel in forum AutoCAD Sheet Set Manager
    Last Post: 2010-01-15, 07:17 PM
  2. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
  3. 2008 LT Sheet set Manager
    By nacirpl in forum AutoCAD LT - General
    Last Post: 2008-05-07, 06:18 PM
  4. Using sheet manager AutoCAD 2008
    By jkeohane in forum Vault - General
    Last Post: 2008-02-08, 01:15 PM
  5. How to use Sheet Set Manager in Vault 2008
    By watersef in forum Vault - General
    Last Post: 2007-11-27, 06:43 PM
