Thread: Applying a Page Setup to all drawings in Publish
    2001-11
    200
    Default Applying a Page Setup to all drawings in Publish
    Hi
    I have just tried to batch plot using publish, but have one problem I need help with.
    WHen I try and create a page setup to use in the batch plot I create one using page setup within a drawing and save it.
    When I try and use publish I cannot find the page setup I have just created.
    What am I doing wrong.
    Neil
    Earth
    9,803
    Default Re: Applying a Page Setup to all drawings in Publish
    You should be creating the page setup in the drawing that you are publishing. Ideally, you should create the page setups in your template drawing(s) so they will exist in every drawing.
    You can also *import* page setups from any drawing from within the publish dialog.
    R.K. McSwain | CAD Panacea |
    2001-11
    200
    Thanks for that
    Neil
  1. PLOT vs PUBLISH: Different results using the same Page Setup
    By k.thomassin957880 in forum CAD Management - General
    Last Post: 2013-07-24, 11:07 AM
  2. 2012: Applying Page setup to all layouts at once
    By Darren Allen in forum AutoCAD General
    Last Post: 2013-01-22, 03:15 PM
  3. Publish error Page Setup works Publish won't
    By jmagarolas962356 in forum AutoCAD Plotting
    Last Post: 2011-02-11, 12:29 AM
  4. 2011: Can't publish using page setup overrides
    By Craig_L in forum AutoCAD General
    Last Post: 2011-02-08, 01:55 PM
  5. Publish to Alternative page setup
    By burchd in forum Project Navigator
    Last Post: 2008-06-03, 06:27 PM
