Thread: Create a Custom Hatch Pattern from a Block
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Create a Custom Hatch Pattern from a Block
    I have ADT 05 and I am trying to make a custom hatch from a block
    What is the best wat to make this a hatch pattern.???
    I can not seem to get this to work....
    Earth
    9,804
    Default Re: Create a Custom Hatch Pattern from a Block
    If you need a true hatch pattern, then you will have to write it, buy it, or contract someone to write it for you. If you just need to fill an area with a pattern of blocks, then use the ET command ._SUPERHATCH
    R.K. McSwain | CAD Panacea |
  1. 2012: Custom Hatch Pattern
    By jagostinho in forum AutoCAD Customization
    Last Post: 2014-12-24, 03:49 AM
  2. Custom Hatch Pattern
    By craigf.56714 in forum AutoCAD General
    Last Post: 2010-11-04, 03:59 PM
  3. Custom Hatch Pattern Help
    By dan302720 in forum AutoCAD Customization
    Last Post: 2010-02-04, 11:49 PM
  4. Replies: 17
    Last Post: 2007-02-08, 06:52 PM
  5. Load custom hatch pattern
    By aungmyatkyaw in forum AutoCAD Customization
    Last Post: 2005-08-01, 12:56 PM
