Results 1 to 8 of 8
Thread: Line Style and View Placement on Sheets?
    2006-07
    31
    Cool Line Style and View Placement on Sheets?
    Simple question. Is there a way to create a line style that can be visiable in the view, but doesn't plot? like a nonplot layer.
    What i am trying to do is locate plans on sheets that are placed on the same location, so i am creating detail lines from corner of sheet to a fixed point to locat all plans/rcp and all at the same location. anyone got a idea?
    2007-03
    Phoenix
    261
    Default Re: Line Style and View Placement on Sheets?
    While there is no such thing as an inherently non-plotting Line element (yet...?), your best bet would be to make the grid/guides out of Reference Lines in your Titleblock Family, and voila, you have a useful grid or set of guides for alignment of views that will not print, just remember to check your Print Setup.
    HTH,
    LC
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    why not create a couple or ref planes. or you could create a line style that you can turn off and on when needed for plotting.
    Justin
    2007-02
    Boston, MA
    92
    One other thing you could do is to have the layout lines in your titleblock family and give them a "display yes/no" instance parameter. We use this to show or hide layouts for detail sheets.
    c
    2005-07
    Somewhere in the BIM world
    3,792
    Got the same here. Simply draw the grid, pick all the lines and under properties pick the little button to the right of visible.
    That will create a yes\no parameter.
    make it an instance one and turn it on or off
    2007-03
    Phoenix
    261
    Same here, too. We use both methods, it depends on the users' preference.
    Here's another thought that is kinda sorta related to this: wouldn't it be great if all of these various methods of providing grids and guides on titleblocks mattered when you really want to line text up with something other than other text without having to eyeball it? Like I said, just a thought...
    Best,
    LC
    2001-12
    Irvine, CA
    7,544
    Quote Originally Posted by echo
    ...when you really want to line text up with something other than other text without having to eyeball it? Like I said, just a thought...
    Nah Elizabeth, that's just talk I hope all is well with your project!
    2007-03
    Phoenix
    261
    Oh, c'mon already, Steve, it ain't all that crazy... just not parametrically intelligent to go back to simple drafting construction techniques, but it would still be nice...
    However, instead, there should be some way to create an intelligent grid system in the Titleblock Family that can have parameter values that then other elements in the model can respond to, like detail tags (e.g. 1,2,3 in the X direction, and A,B,C in the Y directon so that tags auto-fill with A1, C3, etc.). And that intelligent grid should be with Invisible Lines that are visible all the time by default but NEVER print by accident because they're intelligently non-plotting ineherently all of the time. Give the Titleblock Families their own XY coordinates system! Now, there's true crazy talk.
    Best,
    LC
    PS - The project is going well, thanks!
  1. Wall Style Baseline Placement
    By .chad in forum ACA General
    Last Post: 2009-10-22, 04:29 PM
  2. View Placement on Sheets
    By PaulB in forum Revit Architecture - General
    Last Post: 2008-03-28, 02:04 AM
  3. Custom Line Style Manager to Simplify Line Style Creation
    Last Post: 2008-01-09, 09:21 PM
  4. Replies: 2
    Last Post: 2007-09-19, 07:51 PM
  5. Consistant placement of views on sheets.
    By Jshaver in forum Revit Structure - Wish List
    Last Post: 2006-11-18, 03:56 PM
