Hello AUGI Members,
Some time ago Chris helped me setup the attached beam DB to stretch and cut back the ends automatically when placed on a drawing. I am trying to accomplish a few things and have run into trouble with the "parameters" and "actions":
1) The BTAG attribute should always move when the beam is stretched so it would always be at the midpoint of the beam.
2) The BTAG attribute should be scaled to match the drawing scale factor relative to other text on the drawing.
3) If the beam is placed in such a way that the BTAG attribute is upside down....Is there a "parameter" and/or "action" that would flip and rotate the attribute to the other side of the beam so it will read correctly....??
Is this possible....??....If it is I would greatly appreciate if someone could provide a little assistance so I could hopefully get this DB to function properly.
Thank you in advance for your cooperation...!
Regards,
Vince
