Andrewpage23
We would be happy if the models can be edited within Revit. Or at least be linked so that you can do the changes in the other software and it gets update in Revit. Also the floor by face, roof by face, wall by face should be a little bit more flexible. At the moment you can only apply them, on very limited surfaces. If a surface is sloped or too curved, none of those tools would work. The Curtain system panels and mullions need to to be able to flex according to the geometry, so that you can get a perfect draped surface over the imported solid geometry. Revit also needs to maintain it's performance when you import these solids. But probably the most important is that revit needs to able to document the model accurately. Snapping, picking a line and dimensioning on a double curved surface is not possible. I've found a workaround for this problem but it is extremely inefficient. You can export the plans and sections as a 2d DWG then re import them into Revit. The imported lines can be overlayed and be used to snap and pick.
