Thread: AutoCAD 2008 Paperspace dims move when switching between Model/Paper Space
    2005-08
    73
    Default AutoCAD 2008 Paperspace dims move when switching between Model/Paper Space
    We've run into an issue here at my office and was wondering if there's a fix for it. What's happening is we're creating a string of dimensions on a paper space tab then if we switch to the model tab and then return to the paperspace tab without making any changes to the model the dimensions are not in the same place we've put them and have randomly moved. Is anyone experiencing this as well? And what do we need to do to top it from happening?
    13,654
    Default Re: AutoCAD 2008 Paperspace dims move when switching between Model/Paper Space
    Hi
    If possible please post a drawing file that exhibits the behaviour you have described above.
    Have a good one, Mike
    AUGI Addict Augi Doggie's Avatar
    2002-01
    Orlando, FL.
    1,348
    Quote Originally Posted by bill.92885
    Are you moving or deleting any of the entities that the dimensions are attached to?
    Still trying to find out "Who is a good boy?"
  1. 2010: Switching Between Viewports in Paper space
    By WileECoyote in forum AutoCAD General
    Last Post: 2013-11-22, 05:34 PM
  2. 2012: Paper Space Dims Issue
    By Pierre P in forum ACA General
    Last Post: 2012-03-27, 07:57 PM
  3. model space/paper space dims don't match?
    By cadman33619 in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-10-25, 03:05 PM
  4. Move a block from model space to paper space
    By duyen.nguyenthien in forum AutoCAD General
    Last Post: 2010-10-08, 07:56 PM
  5. Lenta regeneracion en Autocad 2008 paper space
    By ggil in forum Español - AutoCAD / AutoCAD LT
    Last Post: 2007-11-29, 01:19 PM
