Results 1 to 8 of 8
Thread: How to dimension a Reflex Angle
    2005-09
    Default How to dimension a Reflex Angle
    I am unable to dimension a REFLEX ANGLE, I can come up to 179d59'59" but cannot dimension past that does anyone know how to set the Dimension Style Manager to read above 180degrees. My work is mainly Land Survey Plans and I need this ability. Please send help!!!
    2006-12
    Big "D"
    3,711
    Default Re: How to dimension a Reflex Angle
    Quote Originally Posted by davidsona
    This is from the help menu from ADT 2007. Looks like it can't be done. I'm not sure about Civil 3D.
    Line Selection
    Defines the angle using two lines.
    Select second line:
    The program determines the angle by using each line as a vector for the angle and the intersection of the lines for the angle vertex. The dimension line spans the angle between the two lines. If the dimension line does not intersect the lines being dimensioned, extension lines are added as needed to extend one or both lines. The arc is always less than 180 degrees.
    Can't you use the obtuse angle instead?
    Why is it called common sense when it is so rare?
    RevitForum.org
    150700
    3,434
    Can you let us know what software you are using, so I can move this to the appropriate forum.
    2005-09
    I'm using Autodesk Map 3D 2008 & learning 2009
    2009-03
    the solution is:
    use the command DIMANG
    Select arc, circle, line, or <specify vertex>:
    press Enter and specify 3 points, the first point must be the intersection of those lines, and the next 2 points are the endpoints of them (oposite)
    and Ready!!!
    regards
    Hi, I have encounter the problem, thanks for sharing!
    Yeah, I have the same problem with you!Thanks for sharing!
    2015-11
    Highlands ranch, CO
    26
    I have a description of how to do this, There is even an animated picture at the bottom of the post
    http://autocadtips.wordpress.com/201...n-180-degrees/
    ~enjoy
  1. How to dimension a Reflex Angle
    By davidsona in forum AutoCAD Tips & Tricks
    Last Post: 2009-04-15, 06:03 PM
  2. Set angle of Dimension Text
    By IanR in forum AutoCAD Wish List
    Last Post: 2007-07-25, 05:23 PM
  3. Field: Adding the dimension angle into a linear dimension
    By alan.rackham in forum AutoCAD Fields
    Last Post: 2007-04-02, 12:48 PM
  4. dimension angle greater than 180 degrees?
    Last Post: 2006-09-13, 03:51 PM
  5. dimension on an angle larger than 180°
    By gravelin in forum Revit Architecture - General
    Last Post: 2005-11-11, 03:36 PM
