Thread: Differences in content of Mtext returned
    2003-11
    Dublin, Ireland.
    152
    Default Differences in content of Mtext returned
    Hi,
    I am looking to extract the contents of a piece of mtext.
    Would anybody have any ideas why, when using this line of code to select mtext :
    (setq AddText (cdr (assoc 1 (entget (car (entsel "nPlease Select Text :"))))))
    that it returns a value of : {fArial|b0|i0|c238|p34;C}11 on some pieces of mtext
    and in other cases it returns the contents of the text without all without all the stuff
    between the {}, which is what I am actually looking for?
    I have attached a sample of two pieces of mtext to demonstrate.
    Thanks in Advance.
    John
    2005-08
    1,043
    Default Re: Differences in content of Mtext returned
    Look in the help files for formatting MText. The string contains the formatting that is applied to the MText object.
    2004-08
    Hartford, Michigan
    3,197
    Quote Originally Posted by jmcshane
    Hi,
    Thanks in Advance.
    John
    Try part of this, I use it to strip text in tables to the default font
    (foreach dp EntDxf
    (if (= (car dp) 1)
    (if (= (wcmatch (cdr dp) "`{*") T)
    	 (progn
    	 (setq leftside (vl-string-left-trim
    	"{\\abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ|0123456789 "
    	(cdr dp)
    		 ) ;_ end of vl-string-left-trim
    	 leftside2 (vl-string-left-trim ";" leftside)
    	 rightside (vl-string-right-trim "}" leftside2)
    	 ) ;_ end of setq
    	 (setq EntDxf (subst (cons 1 rightside) dp EntDxf))
    	 (entmod EntDxf)
    	 (entupd (cdr (assoc -1 EntDxf)))
    	 )	;end progn
    )	;end if
    )	;end if
    "RIGHTSIDE" is the variabl or part that you want, it contains the text without all that other "junk"
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
  1. GetBoundingBox MText actual content only
    By mailmaverick361505 in forum AutoLISP
    Last Post: 2013-12-11, 11:24 AM
  2. Lookup table properties value returned within field
    By Kernal_CAD_Monkey in forum Dynamic Blocks - Technical
    Last Post: 2012-08-24, 04:34 PM
  3. Borrowed Licenses not being returned
    By ROBinHI in forum Revit Architecture - General
    Last Post: 2010-03-04, 10:52 PM
  4. Replies: 6
    Last Post: 2007-05-14, 07:24 AM
  5. Installed '07, and '06 returned
    By dmarx in forum AutoCAD Civil 3D - General
    Last Post: 2006-05-08, 06:50 PM
