Ok I’m up and running with Inventor 2008, Man a lot of new stuff from R8. Hope you guys can help out here.
I need to make a coil that wraps around a rectangle 4 times. The rectangle dims are .25 W x .5 H x 3” L the coil wire is .0313 in diameter and the inside radius will touch the outside of the rectangle. The rectangle will have filet edges that are .0625. Not familiar yet how the wire and piping work. Will I use one of those methods to make this coil or am I going to use the loft tool? I’m not to sure how to make a coil using the loft tool.
