Results 1 to 7 of 7
Thread: Importing Annotative scales
    2007-05
    Gloucestershire
    39
    Default Importing Annotative scales
    The range of scales that I use frequently (1:25, 1:75, 1:125, 1:150, 1:200, 1:250 etc) is not represented in the 'standard' list of Annotation Scales and it is tedious to have to recreate these in every new drawing - is there a way of importing these or making them part of the standard list?
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Re: Importing Annotative scales
    Quote Originally Posted by mtc.139414
    set them in your template.
    scalelistedit will allow you to create new scales.
    you can also bring in an object with those scales associated with it.
    2001-10
    Defragging the internets.
    350
    I attached a script file that I wrote to update my scalelist. You will have to edit it to get the exact list you want but it will give you a good start.
    If you have any questions just ask,
    Chirs
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    If you're working on an existing drawing, try this. Set up a block with your desired scales, then insert it. It's worked for me with older drawings.
    2020-02
    6
    Thirteen years later and Autodesk still haven't addressed this. Would be so much easier if one could simply import annotation scales from another drawing via Design Center.
    Cairo - no, not Illinois
    5,069
    Look for STEALV1-8.lsp on the Swamp.org Solves a some of the things that ADC skips.
    5,714
    Ironically, this post would work for this as well:
    This simplest way I know to 'cleanup scales' for one or more drawings, is to use Autodesk's Cleanup Scales utility:
    (defun c:CleanupScales (/ file)
      (if (setq file (findfile "CleanupScales.exe"))
        (startapp "explorer" file)
        (prompt "\n** File \"CleanupScales.exe\" not found ** ")
    ** You may need separate download for your version; here's a link to 2021 as example:
    https://knowledge.autodesk.com/suppo...2-AE-2021.html
  1. 2012: Annotative Leader at Different Scales
    By Kennaway Elf in forum AutoCAD Annotation
    Last Post: 2013-07-21, 09:41 AM
  2. Default annotative scales
    By Pierre P in forum AutoCAD Annotation
    Last Post: 2012-03-12, 03:05 PM
  3. Changing Annotative Scales
    By jsnow in forum AutoCAD Annotation
    Last Post: 2012-01-17, 02:40 PM
  4. Categories for Annotative Scales
    Last Post: 2008-06-10, 05:06 PM
  5. Can't Change Annotative Scales
    By mockdeep in forum AutoCAD Annotation
    Last Post: 2008-02-14, 12:48 AM
