Results 1 to 6 of 6
Thread: Deleteing redundant geometry
    2006-03
    8
    Question Deleteing redundant geometry
    If memory serves, there used to be a way to erase redundant or overlapping geometry. Am I correct or is that merely wishful thinking? If it does exist, would someone please remind me of the command? I''m using 2007LT. Thank you very much.
    -Jon
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Default Re: Deleteing redundant geometry
    Is OVERKILL a commad in LT?
    2006-09
    Central Maine
    37
    Unfortunately it is not...
    150700
    3,439
    Quote Originally Posted by jstamnitz
    -Jon
    The only ways I know of doing this require a full blown version of AutoCAD; using either OVERKILL (as Scott mentioned) or the DELDUP.LSP file.
    I don't suppose you're fortunate enough to have them on different layers?
    0,0,0 The Origin
    8,570
    The easiest way, in LT, is to use Erase, window what looks like a single line (or a small group of lines), hit `R' for remove and single click the visible line (or each visible line).
    It's okay for small, simple drawings but not much more.
    Not trying to be a smart@$$ but in the long term it would be better to train your users to not produce redundant geometry.
    2006-03
    8
    I was afraid it would turn out to be an other issue with using LT. Unfortunately, the redundancy problems most often lie within architecture files I recieve from clients. If it was an in house problem with my drafters that can easily be fixed (they all know I don't put up with it). And, of course the extra lines and such are all on common layers. Oh well, at least I know now that I'm not just making up commands off the top of my head. Thanks a lot for the help.
    -Jon
  1. Redundant Licenser Server Compatibility
    By gjpete69 in forum Networks
    Last Post: 2016-05-26, 07:28 PM
  2. Redundant Levels
    By scottdurkee in forum Revit Architecture - General
    Last Post: 2011-02-08, 04:39 AM
  3. Deleteing layout tabs without viewports
    By kellyd in forum AutoLISP
    Last Post: 2010-06-16, 07:59 PM
  4. Redundant Systems
    By daniel.morrison in forum Revit MEP - General
    Last Post: 2010-05-20, 12:45 PM
  5. Trouble with users deleteing or moving files?
    By chadley in forum CAD Management - General
    Last Post: 2007-02-26, 04:54 PM
