Thread: AutoCAD 2007 generating PLT files from sheet sets
    2006-12
    3
    Unhappy AutoCAD 2007 generating PLT files from sheet sets
    Some of our clients require PLT files. Using sheet sets, it is easy to generate one large PDF file of all the sheets. However, producing PLT files is not consistent. Obviously, each sheet makes a separate file, but sometimes all the sheets are plotted to individual files, while other times, only the first one is plotted. In both cases, the plot appears to have completed without errors, including listing the individual files for each plotted sheet. Has anyone had similar problems? Has anyone found a solution? Thanks.
    AUGI Addict Augi Doggie's Avatar
    2002-01
    Orlando, FL.
    1,348
    Default Re: AutoCAD 2007 generating PLT files from sheet sets
    Quote Originally Posted by stevee.129391
    Typically a multisheet PLT file is created when the system variable PUBLISHCOLLATE is set to one. That would explain why it happens on some computers and not others.
    If it only plots the first sheet and then stops, that seems to be fixed when you set the BACKGROUNDPLOT variable to 0. At least that's what works for me.
    2006-12
    3
    Thanks. I failed to mention I am using 2007, which does not have that option.
    2002-01
    Orlando, FL.
    1,348
    You should have the "Backgroundplot" system variable, that's been around since 2006. If it only plots the first PLT file and then doesn't plot the others, it's usually that setting that is mucking things up.
  1. Sheet Sets and AutoCAD Electrical?
    By tonofsteel in forum AutoCAD Sheet Set Manager
    Last Post: 2010-01-15, 07:17 PM
  2. AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    By sjz in forum AutoCAD Sheet Set Manager
    Last Post: 2007-08-23, 03:09 PM
  3. Replies: 3
    Last Post: 2007-01-11, 04:39 PM
  4. Sheet Sets - Invisible Plot (PLT) files!
    By dave_s in forum AutoCAD Plotting
    Last Post: 2005-10-31, 03:12 AM
