Results 1 to 7 of 7
Thread: windows in fill areas
    2006-07
    118
    Default windows in fill areas
    i'm having a problem with placing a new window in an existing wall where there was originally a door that was demolished. the wall automatically filled in the hole where the door was removed but when i go to put a new window in the same location, it shows it in plan but in elevation it only shows the outline of the window but it's filled in with the brick wall. any ideas?
    2003-04
    Chino, CA
    4,756
    Default Re: windows in fill areas
    Is the Phase Filter of your view in properties set to "show all"? if so, then infilled wall piece is still showing.
    2006-07
    118
    it's set to show complete
    2006-10
    Arlington, Texas
    596
    Lila, there was a post about this same issue just a day or two ago in this very forum. Do a search, or just look for it in the last few days of traffic. I can't remember what the resolution was, but there is a fairly easy solution.
    Good luck!
    2003-04
    Chino, CA
    4,756
    Quote Originally Posted by lila
    Set it to "Show Existing and New" and then the "demo" piece will go away.
    2006-07
    118
    do you mean "previous and new" i don't have "existing and new"?
    2003-04
    Chino, CA
    4,756
    sorry, yes I meant previous and new! <slapping forehead> Long day...I was in a class when I responded earlier!
  1. hatching cut and fill areas in section view
    Last Post: 2013-11-19, 08:37 PM
  2. Color Fill, Areas or Rooms
    By phyllisr in forum Revit Architecture - General
    Last Post: 2006-11-14, 02:39 PM
  3. Areas - Removing Columns from Floor Areas
    By ddavison.33993 in forum Revit Architecture - General
    Last Post: 2006-02-18, 02:39 PM
  4. Cut and fill areas on cross sections simultaneously
    By aion in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-03-28, 05:20 PM
