Results 1 to 9 of 9
Thread: Userform limit
    2003-10
    706
    Default Userform limit
    Is there a limit to how many userforms one VB program can have? just curious because I have a big 'ol master VB program that launches a ton of other "programs" (different userforms) and was wondering if I'll hit a limit some day... or if this will eventually slow things down.
    Turlock, CA
    6,373
    Default Re: Userform limit
    I'm not aware of any such limit, other than memory. If you run into a problem later, you can break your project up into smaller projects.
    C:> ED WORKING....
    Earth
    9,803
    Agreed.
    Also, in case you don't know about this..... Be sure to open VBAMAN periodically, and run a SaveAs on your DVB file. The file size should be much smaller.
    R.K. McSwain | CAD Panacea |
    Turlock, CA
    6,373
    Quote Originally Posted by rkmcswain
    Temporarily. Doing SaveAs only strips out the compiled code, saving the ascii portion known as pseudo code. As soon as vba compiles it again, the size will be similar to before the SaveAs.
    C:> ED WORKING....
    2003-10
    706
    Is that why when I take my VBA program home to work on it, overwriting what was done the previous night, the file size seems to flop around from large to small and then back again? i'm constantly adding stuff to the program so it should only be getting bigger. I figured it had something to do with the different computers I was running and saving it on from one place to the other.
    I also assume by "ascii portion" you mean the "stuff" we actually type into the code portion of the program? I didn't know it added other compiled "stuff".
    Earth
    9,803
    Lightbulb Re: Userform limit
    Quote Originally Posted by Ed Jobe
    Not exactly.
    I have a 4.9MB DVB file.
    After a SaveAs, the size goes to 1.9MB.
    After a compile of that 1.9MB version, then a save, the file size is 3.6MB - so it still shed 1.3MB of something, somewhere.....
    Turlock, CA
    6,373
    Other things can affect it, e.g. the controls you use.
    C:> ED WORKING....
    Earth
    9,803
    True. That was my only point. That a periodic "SaveAs" can sort of "purge" your file....
    Turlock, CA
    6,373
    Yeah, I wouldn't expect anything dramatic though. Sometime people propose that and they don't go back later to check the filesize, not realizing that compilation takes place.
    C:> ED WORKING....
  1. Room: Upper Limit and Limit offset
    By nnguyen in forum Revit Architecture - General
    Last Post: 2013-01-21, 10:30 AM
  2. Unload a userform
    By mikeosborne in forum VBA/COM Interop
    Last Post: 2009-09-28, 08:35 PM
  3. All I want is a Userform to show..
    By Coolmo in forum Dot Net API
    Last Post: 2009-07-23, 02:03 PM
  4. VBA userform in excel
    By Streng in forum VBA/COM Interop
    Last Post: 2009-02-17, 07:02 PM
  5. Userform sizing
    By Coolmo in forum VBA/COM Interop
    Last Post: 2006-05-30, 11:30 PM
