Thread: CUI Translation
    2006-05
    Pind
    80
    Default CUI Translation
    AutoCAD 2008 is new in the market and most of the companies are still using AutoCAD 2006 Please i would like to suggest that if there is CUI translation utility from 2008 to 2006 it would really help.
    thanks
    0,0,0 The Origin
    8,569
    Default Re: CUI Translation
    Hi.
    What are you trying to achieve?
    If you are not using 2007 or 2008 then CUI is surely not relevant to you?
    John B
    2006-05
    Pind
    80
    when i am customizing the CUI 2008 i want all the library and features in 2006.
    0,0,0 The Origin
    8,569
    You want to migrate custom features from 2006 to 2008?
    John B
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    The migration from 2006 to 2008 should happen automatically when you open the CUI in 2008.
    I do not believe you can convert a 2008 CUI so it can be used in 2006.
    Jeff Paulsen
  1. Translation
    By chrisr in forum AutoCAD General
    Last Post: 2012-04-12, 08:49 PM
  2. Drawing Translation
    By richard.lisiecki in forum CAD Management - General
    Last Post: 2009-07-01, 08:41 AM
  3. IFC to CIS/2 translation
    By jmartin.127555 in forum Revit Architecture - General
    Last Post: 2007-08-12, 09:18 PM
  4. CHS to ENU translation?
    By fjpiper in forum AutoCAD General
    Last Post: 2004-09-29, 08:01 PM
  5. DWG to DWF Translation?
    By ddweld in forum AutoCAD General
    Last Post: 2004-09-15, 02:07 AM
