Thread: Profile Pipe Lengths
    2002-11
    13
    Default Profile Pipe Lengths
    I'm creating sanitary sewer profiles using LDT 2006 with Civil Design. Is there a way to calculate and label the length and slope of the pipes from the inside face of the manhole instead of the center of the manhole? It still needs to be done horizontally (not with the 3D length). The result will be as normal, with 4 LF off the length due to 2' chopped off each end because of the 4' diameter manhole.
    Member DB4-LYF's Avatar
    2008-02
    Springfield, Missouri
    20
    Default Re: Profile Pipe Lengths
    I just do it manually......it sucks but I know its right........
    100 Club Aquaserpent's Avatar
    174
    The reason for center to center is twofold, one it is easier for the contractor to layout, and two you stand a lesser chance of being under in you quantities estimate. Also you will pay for the length of pipe anyway, the contractor is going to charge you for 8 or 20 foot lengths not actual, and he is not going to eat the slop. I understand your desire to be as accurate as possible, but the reality is you are not doing anything that will be recognized in the overall product. Just do center to center and save yourself the time and effort.
    2008-02
    20
    Talking Re: Profile Pipe Lengths
    I agree with the post above...........Where I work people freak if you try and do things automatic.........
  1. 2012: Creating surface profile over Pipe location that is shown in centerline profile
    By karen.cohen593070 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2015-01-21, 11:58 PM
  2. Split Profile Mid-Pipe
    By j_r_sorenson in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-07-15, 03:56 PM
  3. Pipe Lengths in Mechanical Room
    By ljacobs in forum Revit MEP - General
    Last Post: 2010-05-06, 02:02 PM
  4. need help calculating pipe lengths
    By cwjean76 in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-12-04, 09:09 PM
  5. Pipe Profile Editor
    By IanR in forum Civil 3D Wish List
    Last Post: 2008-05-24, 03:17 AM
