Try this. It worked for me.
; Append an object data field value to entities
(defun c:expr2od (/ odt odf expr ss odc i en val)
(if (setq odt (getstring "\nEnter the object Data Table name: "))
(if (setq odf
(getstring "\nEnter the Object Data Field name to append: ")
(if (setq expr (getstring "\nEnter the Expression to evaluate: " t))
(if (setq ss (ssget))
(progn
;; define the new object data field
(setq odc
(list
"columns"
(list
;; same name and description
(cons "colname" odf)
(cons "coldesc" odf)
'("coltype" . "character")
'("defaultval" . "")
;; add the new object data field to the table
(if (not (ade_odaddfield odt odc))
(princ "\nUnable to add new field to Object Data table")
;; append results of expression evaluation into od fields on entities
(repeat (setq i (sslength ss))
(setq
i (1- i)
en (ssname ss i)
val (ade_expreval en expr "string")
(if val
(if (not (ade_odsetfield en odt odf 0 val))
(princ "\nUnable to update OD field on entity ")
(princ "\nUnable to evaluate Expression on entity ")
(princ ".")
(princ "\nNo objects selected ")
(princ "\nNo Expression entered ")
(princ "\nNo Object Data Field name entered")
(princ "\nNo Object Data Table name entered")
(princ "\nDone")
(princ)
) ; c:expr2od
[ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
