Thread: Tapered Wide Flange Beam
    2005-11
    76
    Post Tapered Wide Flange Beam
    Hi,
    this is my first family editing attempt and as sketchy as it is I hope it'll come in handy for you guys out there:
    I've morphed an existing wide-flange family into this new type that allows to edit one of the beam's end height, thus creating a tapered beam. In the 'Edit' window, go to the very bottom and enter a height for "d-short".
    Somewhere along the road I lost the ability to stretch the beam, though. It would be great to have that option, and I can't see a way to tell the 'Solid Blend' to have a parametric length...any help?
    Axel
    2005-07
    3,250
    Default Re: Tapered Wide Flange Beam
    Here's one I did a while ago. Feel free to reverse engineer.
    2005-11
    76
    Hey David,
    that is a great help to also have the "no taper length" feature! I will reverse engineer and see how things are done and then see if I can add a taper on the other end [quite practical for my project].
    Axel
    2005-07
    3,250
    NP Axel So you need something with a taper on both sides? I think I'd just model two beams side by side (it's how it would probably get built anyway).
  1. 2015: Wide Flange beam encased in Concrete?
    By Andi in forum Revit Architecture - Families
    Last Post: 2015-07-20, 04:37 PM
  2. Bring back shape handles to the wide flange beam family.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-10-10, 09:33 PM
  3. 2013: Changing Coarse Level of Wide Flange Beam in Framing Elevation
    By tjk.267140 in forum Revit Structure - Families
    Last Post: 2013-04-03, 12:53 PM
  4. Hole in Wide Flange Beam
    By rmcelvain.103137 in forum Revit Structure - General
    Last Post: 2006-06-02, 05:10 PM
  5. Two plumb cut for wide flange beam
    By thalim in forum Revit Structure - General
    Last Post: 2005-08-30, 03:18 AM
