Results 1 to 9 of 9
Thread: Roofing
    2005-04
    Saintlouis Missouri
    529
    Default Roofing
    Is there any way to get the surface material of the roofs lighter? It is screened out in the VG settings. Thanks for the info.
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    Default Re: Roofing
    Have you tried changing the colour of the hatch pattern? That works for me.
    2004-06
    waaaaay EAST of the 5
    172
    Default Re: Roofing
    I was wondering if it is possible to change the scale. The wood shake shingles work for the project on which I am working. Though when I plot at 1/4" = 1'-0" the shingles are too small and appear crowded and also too dark due to the density.
    I could stop if I wanted to whittendesigns's Avatar
    2004-07
    330
    Default Re: Roofing
    That is usually because you have told Revit to use a drafting hatch instead of a model hatch.
    2002-02
    St. Louis, MO
    4,695
    Default Re: Roofing
    Quote Originally Posted by whittendesigns
    Actually in this case - the other way around. The shigles are real world size and the lines are getting too tightly spaced at 1/4".
    A. Override the shingles to use a gray line ather than a black.
    B. Use a shingle pattern that has a bigger spacing.
    C. Just turn off the shingles below a certain scale.
    2005-04
    Saintlouis Missouri
    529
    Default Re: Roofing
    Thanks, I will take all that into consideration and see what works best.
    2004-06
    172
    Default Re: Roofing
    Quote Originally Posted by aaronrumple
    Is this for the OTB pattern?
    2004-07
    330
    Default Re: Roofing
    Aaron's more than likely right. I usually just use model patterns. The drafting patterns always get screwy for me. If you use a model pattern, it doesn't matter if your view is 1/8" or 1/4" or whatever, it shows the same. When I did, going to a larger scale made my pattern more dense, thus my answer previously. So if you started with 1/8" and went to 1/4", it would double the density of the pattern.
    If you want to adjust the size of the pattern, edit your materials under Settings. What I have to do is redo the hatch pattern, meaning it's like I'm telling it for the first time, "select this one", then the scale adjustment will turn on. Mine stays grayed out unless I take this one step
    2004-06
    172
    Default Re: Roofing
    I am attempting to delete the current pattern and add the edited one. I must be overlooking something as I cannot get a grip on the pattern.
  1. Roofing Caps
    By Mike_Maloney in forum Revit Architecture - General
    Last Post: 2009-09-17, 02:19 PM
  2. Roofing Question
    By harkeychad in forum Revit Architecture - General
    Last Post: 2008-05-21, 06:34 PM
  3. Roofing Question 2
    Last Post: 2008-05-21, 02:12 PM
  4. Roofing area, aka how many squares of roofing
    By tjhernacki in forum Revit Architecture - General
    Last Post: 2007-10-27, 03:15 PM
  5. Flat roofing
    By PeterJ in forum Revit Architecture - General
    Last Post: 2003-07-17, 07:51 AM
