Hi,
I have many files containing two title blocks in each, that need to be replaced with new versions of the same blocks and have the attribute values of the new versions replaced with the attribute values from the old.
I have attempted this using lisp (it doesn't work) and have likely made fundamental errors in the application of lists (see attached). My feeling is vlisp might work best, especially when incorporating windows explorer to select all the folders with drawings required for batch processing; or would that be VBA. I have reviewed some of the threads on attributes such as:
http://forums.augi.com/showthread.ph...ight=attribute were kennet.sjoberg posted a nice bit of vlisp code, but haven't been able to put all the pieces together.
Any thoughts?
Brad
