Results 1 to 10 of 13
Thread: VAB routine working in Civil 3D 2007, but not in Civil 3D 2008
    2007-06
    44
    Default VAB routine working in Civil 3D 2007, but not in Civil 3D 2008
    Hi all,
    I have a slight problem. I wrote something for use in 2007 and i made it general so that when you change versions it would not affect the program. Basically I have a Parcel declared as a VB object. I then set this later to be an actual parcel. However my problem comes when I am trying to rename it. I run this in 2007 and it works just fine. However the same line of code gives me an "access is denied" message box. Basically this is what I have.
    Dim Parcel As Object
    { ...stuff to get the parcel... }
    Parcel.Name = Textbox1.Value & "-" & Parcel.Name
    Again, this works fine in 2007, but not in 2008. I also have a case statement that determines that it is in 2008 in case you were curious.
    Select Case AcadVer
    Case Is = "16"
    sAppName = "AeccXUiLand.AeccApplication.3.0"
    Case Is = "17.0"
    sAppName = "AeccXUiLand.AeccApplication.4.0"
    Case Is = "17.1"
    sAppName = "AeccXUiLand.AeccApplication.5.0"
    Case Else
    MsgBox "Invalid Civil3D version, exiting."
    Exit Sub
    End Select
    Thank you very much for the help.
    ~Chris
    2007-06
    44
    Default Re: VAB routine working in Civil 3D 2007, but not in Civil 3D 2008
    Hi,
    I actually tried to make this C3D2008 specific so I took out all of the stuff about checking the version and the object stuff. I am now actually making an AeccParcel. Yet when I set the name like Parcel.Name it is still giving me an "access is denied". This line works great in 2007. Is this a bug or something, or am I just doing something wrong.
    Thanks,
    ~Chris
    150700
    3,439
    This is a VBA program? If so, I'll move this over to the VBA forum, you'll have better luck there.
    2007-06
    44
    OH!!!! Yes sorry about that.....Thank you very much...
    150700
    3,439
    Quote Originally Posted by Christopher.cornell
    No apologies required
    2007-06
    44
    I actually tried renaming this in the drawing as well. I get the same error. I am just going to assume that this is a bug of somesort. Can anyone else rename parcels.
    6,417
    Locked layers perhaps? Before you assume its a bug, try to isolate if its just a single dwg, pc, etc.
    LinkedIn
    2007-06
    44
    No I do not think the layers are locked. I will check really quick but I dont think that is it. It is a really weird error because I do the same thing in C3D 07 and it works fine, so I was just a little confused as to what is happening.
    EDIT: I checked that, the layers are all unlocked.
    6,417
    Try to isolate further. Can someone else on another pc do it? Can you do it in a new, clean file? Can you try it on a pc with only 2008 installed? If you have subscription, submit a support call.
    LinkedIn
    2007-06
    44
    I have not yet tried it on another PC? It does not work with a new, clean file however. I also have not tried it with just 2008 installed. I guess I will try and submit a support call. Thanks for all of the help.
  1. Replies: 0
    Last Post: 2013-04-17, 04:53 AM
  2. Replies: 0
    Last Post: 2008-02-11, 08:11 PM
  3. Workspaces from Civil 3D 2007 to Civil 3D 2008
    By a.bygrave in forum AutoCAD Customization
    Last Post: 2007-12-05, 10:43 PM
  4. Webcast for Civil Engineers: Introduction to AutoCAD Civil 3D 2008
    By Brogueira-CADptbr in forum AutoCAD Civil 3D - General
    Last Post: 2007-02-26, 10:34 PM
  5. Civil 3D 2007 - How does file structure and standards relate to Civil 3D
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-01-22, 06:05 AM
