Does anyone have window families for the attached image. I can use a single hung with transom, but I was wondering if someone had them all together.
Kevin
Kevin
Attached is a .zip file of families I made for you that approximate your images. Without a section, I was unsure exactly what you wanted so it was a guess.
These are way more complex than you probably need but I had something very close already created for a specific project so this did not take much time. Hopefully, it is not too confusing - this is not something I consider elegant and easy to use and is not necessarily an example I would emulate if I were you. But it might work if you are in a hurry....
Phyllis,
Thanks! Sorry for my late reply! I miss your post earlier.
They are somewhat basic but for right now they will work to keep us going with what we are doing. As for how they look in section, I will need to do some adjustment for wall sections or work out a new family with my standard single hung windows.
Thanks again!
Kevin
