Results 1 to 6 of 6
Thread: How do you create a Shadow effect in Impression?
    2001-08
    Dacula
    226
    Default How do you create a Shadow effect in Impression?
    How does one create a shadow effect in Impression?
    TC
    2005-07
    2,356
    Default Re: How do you create a Shadow effect in Impression?
    Quote Originally Posted by captainbunsaver
    TC
    How do you mean? A shadow to buildings, trees etc?
    2002-07
    10
    The easiest way is to add the drop shadow fx to your style. You style should have a fill in it of some kind. You can then hit a checkbox to cast the shadow internally or externally.
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    If you are talking about shadows on building elevations, you will have to do them the old fashioned way if you are working in Autocad. I make a separate file of the shadow hatches, bring them into Impression, then apply a single style to all the shadows and make that into a block which I then import into my main file. Sounds complicated but it is quick and you can control all your shadows by fiddling with the settings in your block.
    2006-08
    34
    Quote Originally Posted by Joef View Post
    Have you got an example image you could post?
    I would be interested to see it.
    2005-07
    2,356
    Quote Originally Posted by nlegge View Post
    You can view sample drawings created in Autodesk Impression here.
  1. GD315-2P: Using Autodesk Impression to ... Make an Impression!
    By Autodesk University in forum General Design
    Last Post: 2013-05-06, 01:36 AM
  2. GD32-1L: Making a Good Impression with Autodesk® Impression
    Last Post: 2013-04-17, 04:59 AM
  3. Replies: 0
    Last Post: 2013-04-17, 04:52 AM
  4. shadow studies with different color shadow
    By sami in forum Revit Architecture - General
    Last Post: 2008-12-04, 03:18 AM
  5. Roof plan shadow effect
    By christo4robin in forum Revit Architecture - General
    Last Post: 2003-05-16, 11:41 PM
