Thread: Predefined text strings
    2004-07
    Detroit Michigan
    2,508
    Default Predefined text strings
    Is there a way in AutoCad to customize autocad to use predefined text strings?
    I have to change some dtext in an engineering change box to read "UPDATE REV LEVEL".
    It would be nice if I had some predefined text strings that I could choose from.
    2006-10
    Chicagoland
    154
    Default Re: Predefined text strings
    I have some LISP routines that create predefined text, or also, text I type in. These are useful in my line of work for labeling easements. Although these routines are for new text creation, with a little modification, you can use it to edit text, also.
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by margaretl
    Those are some good routines, thanks for sharing.
    I have also thought about using dynamic blocks.
    I do not think my text is generic enough for a block.
    I could drop a list of predefined text into the drawing and use the
    matchtxt command.
    Too many options
  1. Linking text strings
    By DaleSmith in forum Revit Architecture - General
    Last Post: 2011-11-25, 09:26 AM
  2. text strings on schedules?
    By timsea81 in forum Revit MEP - General
    Last Post: 2009-05-08, 04:30 PM
  3. Text strings in Dimensions
    By DaveP in forum Revit Architecture - Wish List
    Last Post: 2006-06-26, 12:34 AM
  4. Match text strings by selecting
    By spaynter in forum AutoLISP
    Last Post: 2005-10-12, 08:32 PM
  5. formating text strings
    By rwbaker in forum VBA/COM Interop
    Last Post: 2005-09-20, 06:02 PM
