I just doiwnloaded DWG TrueView so I could batch convert all our Design Center files for the new ACA2008. The Help says the following:
"You can choose the file format, several conversion options, and the type of output you want.
With DWG TrueView, you can convert AutoCAD DWG files between the following data formats:
AutoCAD 2008 (not a format change, but includes new data)
AutoCAD 2007
AutoCAD 2004
AutoCAD 2000
AutoCAD R14, AutoCAD LT 98, AutoCAD LT 97"
However, I don't see an option for converting to 2008, only 2007. I know it's the same format, but the design center in 2008 still gives me a message that the files need to be saved in 2008, even after I have converted them to 2007 format. Is there an option to convert to 2008? Thanks.
