Thread: Light fixture sched - total watts?
    100 Club Fred Blome's Avatar
    2003-05
    Palo Alto, California
    143
    Default Light fixture sched - total watts?
    In my light fixture schedule, I am trying to total the wattages for each fixture type. "Wattage" is a system family and doesn't appear to be a "number" catagory, so it won't total. Am I missing something? The only workaround I've found is to add another field for watts and re-enter the same info.
    Thanks.
    (Why do this? California Energy calcs for residential require tabulation of all kitchen fixtures with wattages)
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Light fixture sched - total watts?
    Unless you use Revit MEP you will need to add another parameter and calculate that value.
    2006-10
    Arlington, Texas
    596
    Yep.
    Add a calculated value parameter...
    2006-03
    61
    Is there any rational explanation why a system parameter, "Wattage", is saved as text?!?
    thank you
    gio
    2007-06
    55
    agreed! "Wattage" seems a mostly useless parameter, the only function I can think of being to write in (as text only) the wattage of lamps used in the fixture one is scheduling. It can't even be used in a calculated value formula because it isn't a number - grrr... I'm about to go add my own parameter to all these families so it can actually be used for something.
  1. 2014: Light fixture does not produce light in rendering
    By ctc in forum Revit Architecture - Families
    Last Post: 2014-04-11, 07:56 PM
  2. Replies: 0
    Last Post: 2013-04-04, 05:40 PM
  3. Revit light fixture light source geometry won't go away
    By david_spehar in forum NavisWorks - General
    Last Post: 2012-02-21, 09:05 PM
  4. Generic Light Fixture Familys vs Project Specific Fixture Data
    By AnnieJ115 in forum Revit MEP - General
    Last Post: 2011-09-28, 05:37 PM
  5. Light fixture shown 0 volts and 0 WATTS(VA)
    By revit_wannabe in forum Revit MEP - General
    Last Post: 2009-05-04, 08:24 PM
