Thread: Multiple block insert
    2001-05
    17
    Default Multiple block insert
    Is there a way to select multiple (dxf) files when inserting as blocks? I want to create a backdrop that consists of 100 individual survey files. I can insert into my file one by one, but it is tedious!
    Thanks
    Matt
    Português - Programação Moderator Filipe Francisco's Avatar
    2001-12
    * PORTUGAL * Sintra *
    859
    Default Re: Multiple block insert
    Quote Originally Posted by mgb3
    Thanks
    Matt
    Use Design Center ( CRT+2 ) to do that
    Cheers,
    2001-05
    17
    I had tried that, but Design Centre doesnt seem to recognise dxf files (unless Ive got something set up wrong)
    Autocad 2004
    Thanks
    Matt
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Thanks
    Matt
    Instead of inserting it using the _INSERT command, you can simply drag the dxf file from the explorer window and drop it on the target AutoCAD window to be inserted as a block reference.
  1. Insert a Tool Palette Block While Editing a Block or Xref.
    Last Post: 2013-10-07, 04:53 PM
  2. Insert a block on multiple layouts
    Last Post: 2012-11-14, 01:03 AM
  3. How do you multiple insert a block in 3d
    By rvthor in forum AutoCAD General
    Last Post: 2010-11-05, 01:46 PM
  4. Multiple block insert into any closed shape?
    By fomikaze in forum AutoCAD General
    Last Post: 2007-06-18, 04:59 PM
  5. Replies: 19
    Last Post: 2006-03-14, 05:06 PM
