Results 1 to 6 of 6
Thread: shadow with mental ray
    Member hausmeister25's Avatar
    2006-04
    London
    27
    Default shadow with mental ray
    I stuck. I cant find the shadows on this picture.
    I rendered it with the mental ray settings in Max 9, see attached.
    Shadow is turned on, a daylight system has been created.
    Are the settings correct?
    Only, when I use the standard sun, I get the option to turn on shadows.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: shadow with mental ray
    I dunno dude. I setup a very basic scene and it worked. First I switched the UI to run mr settings, then built a box with some spheres above it. added a daylight containing an mr sun and sky. opened the render box and activated the mr render engine. rendered it and all spheres cast shadows. ~shrugs~
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2006-04
    London
    27
    I get shadows with mental ray, if ray tracing is switched on!
    Ray tracing takes up a lot of memory and time. Does anybody knows, if there is another option? Cheers.
    2015-12
    4,730
    Well, I can't imagine running mr without ray trace, as that is what refines the edges of shadows - among other things.
    Member gurudas.ku's Avatar
    2006-10
    NewDelhi
    39
    dude
    try to switch on shadows and select mr shadow and in render option go to indirect illumination switch on final gather, if u want to use a sky light that will great to get accurate
    cheers
    if raytracing is not active you cant use indirect illumination...is like you use scanline only.
    if you use low values for FG and GI you cand take low times..
  1. First mental ray....
    By Martin P in forum Revit - Gallery
    Last Post: 2011-04-13, 07:41 PM
  2. Mental Ray GPU
    By METANAMORPHOSE in forum 3ds Max - General
    Last Post: 2009-10-02, 07:21 AM
  3. shadow studies with different color shadow
    By sami in forum Revit Architecture - General
    Last Post: 2008-12-04, 03:18 AM
  4. standalone mental ray vs. 3ds Max's internal mental ray
    By stusic in forum 3ds Max - mental ray
    Last Post: 2007-04-17, 04:18 PM
