Results 1 to 8 of 8
Thread: Is it possible to run .NET applications in AutoCAD LT
    Default Is it possible to run .NET applications in AutoCAD LT
    hello
    Is there any way to run vb.net application on autoCAD LT? Maybe there is some extension to aotuCAD LT, that handles netload command, (LT-extender doesn't support netload) or some other way. Thx for any reply
    regards
    Jarek Marciniak
    Earth
    9,804
    Default Re: Is it possible to run .NET applications in AutoCAD LT
    As far as I know, the answer is no.
    R.K. McSwain | CAD Panacea |
    2006-03
    20
    Yes it is, but only at startup.
    In the registry, there is a list of arx's and dll's that are loaded when autocad lt starts. Just add your application.
    I probably shouldn't go into more detail, scince Autodesk doesn't approve customizing Autocad lt.
    Turlock, CA
    6,416
    The only thing I know of is the toolkit from DrCauto.com. It supports ObjectArx but doesn't mention NETLOAD. LISP is supported though.
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,416
    Quote Originally Posted by zeljko.gjuranic View Post
    You might be able to specify a file, but does it actually load and continue working? I don't have LT, so I can't test your claim.
    C:> ED WORKING....
    LinkedIn
    2006-03
    20
    I'm not 100% sure, I also don't have LT.
    I've tried it on LT 2008, but with LT extender installed, which provides netload functionality.
    Unfortunately, this add-on is no longer developed.
    Turlock, CA
    6,416
    Autodesk's lawsuit killed extender.
    I think that NETLOAD is the key. Otherwise, LT only recognizes the dll's it ships with. Someone would need to test it though. Perhaps Jarek could report back here if he gets it to work?
    C:> ED WORKING....
    LinkedIn
    2007-04
    81
    What makes LT cheaper is the removal of customizing ability, that is lsp and such.
    Patrick Johnson
    http:\\www.cadenhancement.com
  1. CP214-4: AutoCAD .NET: Using .NET With Your LISP Applications
    Last Post: 2014-12-01, 01:45 AM
  2. CP32-1: Facelift Your AutoCAD Applications with .NET
    Last Post: 2013-04-17, 04:23 AM
  3. Autocad français vs applications en anglais
    By christian.lacroix in forum CAD Management - General
    Last Post: 2008-11-28, 07:56 AM
  4. Get AutoCAD or extend AutoCAD LT with Third-Party applications
    By jens.liljegren in forum AutoCAD LT - General
    Last Post: 2007-02-28, 02:29 PM
