I'm modifying our firm's wall tag to match a newly developed standard. The tag allows for a field of additional description if necessary. I was hoping that I could create a label in the annotation family that referenced a yes/no visibility instance parameter. I tried with no luck, but when I switched the yes/no parameter to a type parameter, it showed up in the project. I am correct to assume that you can't use a yes/no instance parameter in an annotation family?
