Thread: Unassociated AEC dimension
    2005-10
    8
    Default Unassociated AEC dimension
    I'm currently using AutoCAD Architecture 2008 formely know as ADT. I inserted a series of AEC dimension into the drawing. A number of "0" value dimension were created with the AEC dimension. The wall is a single component AEC wall object. There is no apprent reason why these "0" value dimension was created by the program. Is this another AutoCAD bug? I needs to menually ellimated these "0" value dimensions.
    Also after editing the drawing severl time some of the AEC dimension become disassociated with the wall entity. When I move the wall the dimension does not follow.
    Has anyone elese experience the same problem?
    Any advise or helpfull commenst will be appreciated.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Unassociated AEC dimension
    In regards to your first question, it has to do with walls drawn improperly. All walls justification lines need to touch neatly. If they do not, you will get the 0" dims showing up.
    As for the second question, I've not seen that happen. Can you post an example?
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2005-10
    8
    Unhappy Re: Unassociated AEC dimension
    Thanks for your comments. I tried to clean up the wall along the northe side of bedroom 4 and I'm still getting "0" value dimension!
  1. Show Clash Symbol When a Dimension Overlaps Another Dimension
    Last Post: 2013-11-18, 08:31 PM
  2. Replies: 6
    Last Post: 2011-04-25, 07:55 PM
  3. Leader with unassociated text...
    By awill81226338 in forum AutoLISP
    Last Post: 2009-07-16, 11:40 AM
  4. Leader with unassociated text...
    Last Post: 2009-07-15, 08:27 PM
  5. Replies: 2
    Last Post: 2007-04-17, 03:08 PM
