Results 1 to 6 of 6
Thread: Single line piping
    All AUGI, all the time JoelLondenberg's Avatar
    2015-10
    508
    Default Single line piping
    I must be missing something simple here. I'm attempting to show a waste line below slab as the single line symbology. This seems to work fine in a section view simply by switching the detail level to low or medium. In plan view it stays double line no matter what the detail level.
    Anyone know where the check box is to fix this?
    Joel Londenberg
    BIM Box Biz - Serving all MEP Contractors
    "The best you can hope for in this life is that your delusions are benign and your compulsions have utility." - Dilbert author Scott Adams
    This is the correct date format
    2006-12
    33
    Default Re: Single line piping
    A potential reason for this could be you have a special setting for plan view.
    Check properties of plan view and go to view/ Graphic, then a dialog box show up.
    Please check the "Detail Level" for pipe category, is By View or not.
    I guess, it maybe "fine" there.
    2007-08
    11
    I have run into this problem before. The cause is the View Range under your View Properties. You have to set both your Primary Range - Bottom and View Depth - Level offsets to a value below your pipe and that should fix it.
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Quote Originally Posted by mott-45
    That's a helpful first post, thanks for chiming in mott.
    Kyle B
    Product Line Manager
    Revit Services
    Smart Questions = Smart Answers
    2015-10
    508
    This was the bit that fixed it, thanks guys.
    Joel Londenberg
    2004-07
    Tucson
    11
    I didn't find this solution to work completely for my standard, unless I'm missing something. When I change the View Range setting, my pipe changes from single dash line style (from the "beyond" line style definition) to a double dash line. My standard maintains the single line for the below slab pipe as well. What I use is a filter defined as Sanitary Below Slab, assign to pipe category, and set the value less than the reference level elevation for "invert elevation". Then add the filter to Visibility Graphics and select the line pattern override I need. Make sure to then apply proper elevation settings for the View Range in the View Properties. See attached images.
  1. Single & Double line piping on same view
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-07-16, 07:32 PM
  2. Replies: 3
    Last Post: 2012-07-09, 04:54 PM
  3. Single Line Piping Rise/Drop Issues
    By mrkuhl in forum Revit MEP - General
    Last Post: 2009-01-16, 09:38 PM
  4. Single Line Piping
    By sgermano in forum Revit MEP - General
    Last Post: 2009-01-10, 10:19 AM
  5. Single line piping.
    By cmguerra in forum Revit MEP - General
    Last Post: 2008-01-07, 04:41 PM
