Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
Thread: New Bonus Tool! "Command Complete"
    AutoCAD Product Manager eric.stover's Avatar
    2001-02
    San Rafael, CA
    35
    Default New Bonus Tool! "Command Complete"
    AutoCAD fans, our developers have created a new bonus tool for you to test drive up on our Labs site:
    http://labs.autodesk.com/utilities/CommandComplete/
    CommandComplete is ‘Intellisense’ for the AutoCAD command line, providing easy access to over 1400 commands and sysvars. As you type in the command prompt, a popup list appears displaying the list of commands and sysvars that match the input. This bonus tool can save AutoCAD command line power users a lot of typing.
    The auto-complete list is based on one or more of the following (selectable) search criteria:
    Start with your typed string -- Displays all matches where the command/sysvar begins with the text typed at the command line. For example, typing "LI" would list "LINE", "LIGHT", etc. (This base option is not selectable).
    Anywhere search -- Displays all matches where the command/sysvar contains the typed text anywhere in its name. (For example, typing "LI" would list "LINE", "PUBLISH", "ALIGN", etc.
    Keyword search -- Additional keywords can be defined in an XML file for every command. This option displays all commands/sysvars where the typed text is contained within one of your keywords. You can include keywords by editing the XML file.
    Let us know what you think!
    Eric
    150700
    3,439
    Default Re: New Bonus Tool! "Command Complete"
    Quote Originally Posted by eric.stover
    Eric
    Will this work with 2007 or other versions, or is this strictly an 08 thing?
    2001-02
    San Rafael, CA
    35
    This will work on ACAD 2007 as well.
    Thanks -Eric
    I could stop if I wanted to ekubaskie's Avatar
    2001-12
    Anchorage, Alaska
    324
    So Eric, sharing your web server time with AU registration today? All I'm getting is a blank page, F5 after F5...
    150700
    3,439
    Quote Originally Posted by ekubaskie
    I had that.. and then this
    Fatal error: Cannot run code from this file in conjunction with non encoded files in /var/www/html/_autodesk.com/labs/releases/20070815014933/portal.inc.php on line 12
    0,0,0 The Origin
    8,570
    I'm getting a blank page - a problem with Firefox, perhaps.
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Quote Originally Posted by jaberwok
    Not Firefox related. Same with IE.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    Thanks, it looks pretty sweet so far.
    OK, now that I have tried it more, I don't like it, it is locking up the computer for a few seconds, and the search doesn't make any sense. Sometimes it will locate words based on the first two letters only, then on three, or none. Basic commands/sysvars like msltscale, line, move can't be found with the first two or three letters typed.
    Spend your time on existing problems in the program.
    150700
    3,439
    Quote Originally Posted by kent.elrod
    lucky
    Still trying
    0,0,0 The Origin
    8,570
    That fixed it.
  1. Replies: 8
    Last Post: 2012-08-18, 01:31 AM
  2. "Missing Curtain Panels will be replaced with System Panels to complete command."
    By ktracy.194130 in forum Revit Architecture - General
    Last Post: 2008-12-07, 09:08 AM
  3. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 12:41 PM
  4. Replies: 3
    Last Post: 2006-03-23, 10:25 PM
  5. Replies: 1
    Last Post: 2005-11-15, 07:35 AM
