Is it possible to use a field as the layout tab name? I would like to reference the Sheet Set Number and make it the layout tab name.
Thank you.
Craig II
Thank you.
Craig II
nope, and to see for yourself, rename and r-click. no option for field available...Originally Posted by csiress
S&D DB Sharing Forum
Any script or lisp to do so?
I would think that there would be something out there.
I cannot be the first to think of using fields as the layout tab name.
Thanks
Craig II
This would be good. I have looked at this in the past and found no way of getting my TitleBlock Drawing number (attribute) inserted in the Layout Tab name
There will be a way with the 'expected layout' attribute from the sheet set properties, but i dont know, yet
Let us know how you get on.
Cheers
There is a way to do this. Simply create a field, referenced to the System Variable "ctab".
You could always just go through and rename/renumber them from the SSM dialog, since that option is in there. At least then you don't need to open each one.
