Your thoughts GOOD, BAD and OTHERWISE on the following shift using available 2008-based software
BACKGROUND
I am in a smaller chemical processing environment where I work alone and have admin privileges (unheard of) and on Autodesk Subscription using Inventor 2008 Routed Systems Suite. Here is the situation
#1 AutoCAD Vanilla has improved with 2008....
PLAN to NOT use AutoCAD Mechanical 2008 for 2D i.e. process-related diagrams (P&ID's, isometric piping, etc.) as I started doing due to my experience with it as a machine designer at another company and its scaling features, standard-based toolset and 2D parametric standard parts library including structural shapes.
NO GO on AutoCAD P&ID due to cost and most P&ID's are in place & no database functionality required per mgmt. I tried to sell it.
#2 Inventor 2008 Routed Systems Suite....
PLAN to NOT use AutoCAD Mechanical 2008 for structural ( platforms, vessels) & piping layouts and assoc. design work going 3D all the way with Inventor 2008 (after gaining some experience, that is) I have been formally trained (beginner course).
Have any of you made a similar shift lately? What are some things to consider?
