Thread: Sheet Manage Custom Properties
    ACAD Wish List Administration
    2005-06
    1,920
    Default Sheet Manage Custom Properties
    Summary: Sheet Manager custom properties to be inserted in the model and updated automatically.
    Description: I wish that Sheet Manager custom properties could be inserted in the model and could be updated automatically just like if they were in the layouts.
    Example: I created a custom sheet set property "NumberOfSheets". I wanted to insert that field in a piece of text for match lines "See Match Line A-A on Sheet 7 of 51" (51 being the NumberOfSheets" field.
    Then I add sheets in the project and I update the NumberOfSheets field in the sheet set.
    The field will only update if I insert the block in the layout. It also works after I update the field in floating model, but the field will not update directly in the model for blocks inserted in the model. Why?
    How Used: Some sheet properties belong to the model. Give users the choice to determine where the custon properties will update automatically.
    Feature Affinity: Fields
    Submitted By: Jacques Lallemand on July 10, 2007
    2002-06
    39
    Default Re: Sheet Manage Custom Properties
    I agree that this would be very handy.
    This probably goes back to having one sheet per drawing though, I think.
    Kmelchor
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    As Kim stated this could only work if you only had one sheet per drawing or if every sheet in the drawing was in the same set.
    If you had two sheets in a drawing but they were both in different sheet sets the software would not know which sheet set's properties to apply.
    Jeff Paulsen
  1. Sheet set / Sheet custom properties data validation
    By tawfik72 in forum CAD Management - General
    Last Post: 2010-11-22, 11:54 AM
  2. Custom sheet properties
    By Bryan Thatcher in forum ACA General
    Last Post: 2009-03-13, 06:56 PM
  3. Replies: 5
    Last Post: 2009-02-23, 09:12 PM
  4. Sheet set custom properties
    By feargt in forum VBA/COM Interop
    Last Post: 2009-02-16, 11:34 PM
  5. Sheet Set Custom Properties
    By kschultz in forum AutoCAD Sheet Set Manager
    Last Post: 2005-09-02, 05:48 PM
