Discovered a problem with qleader in AutoCad LT (04). The default arrow style is closed-filled. Everything works fine until you change the style. If I then try to reset the style to closed-filled, it doesn't work; the arrow will be drawn in the previously selected style and when you go back into settings that previous style is shown. If you pick other styles, the program works normally. The problem seems to be with the closed-filled style only.
Once a qleader has been placed (in some other style), it's properties can be changed to a closed-filled style.
What is going on?
