Thread: roof section visible in interior elevations
    2007-03
    17
    Default roof section visible in interior elevations
    I have a pitched roof with no drop down ceiling. In my interior elevations, revit shows a section view of the roof. Right now I'm just creating mask regions over the roof to cover the section details, but its getting tedious considering the number of interior elevations I have to do. Any suggestions?
    Thank you in advance.
    Moderator JamesVan's Avatar
    2016-01
    New York, NY
    625
    Default Re: roof section visible in interior elevations
    Do you want a single, angled line to depict the top of the wall in the interior elevation? If so, the masking region is the only way to do this in today's Revit. If you don't need the entire wall elevation, you could just drag the crop region below the roof.
    2003-05
    Northbrook, IL
    879
    Use the linework tool to make the upper edge of the roof invisible. You will have to do it in every view but it is faster than filled regions.
    2007-03
    17
    thank you. I have to have an angled line depecting the top edge of interior roof. I will continue with my method or use the suggested invisible lines.
    thank you for all your help.
  1. Outline of interior visible in 3D model
    By clog boy in forum Revit Architecture - General
    Last Post: 2008-10-24, 06:40 AM
  2. A B C D on interior elevations
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-08-01, 03:25 PM
  3. Interior Elevations - Cut Box?
    By jtl in forum Revit Architecture - General
    Last Post: 2007-10-26, 04:17 PM
  4. Interior Elevations
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2007-05-30, 07:08 PM
  5. Where is Interior Elevations?
    By ford347 in forum Revit Architecture - General
    Last Post: 2005-12-06, 06:50 PM
